주요 콘텐츠로 건너뛰기
Trek 4300 Bicycle Front Wheel Replacement
  1. Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: 1 단계, 이미지 1/2 Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: 1 단계, 이미지 2/2
    • Stand facing your bike and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
  2. Trek 4300 Bicycle Front Wheel Replacement: 2 단계, 이미지 1/2 Trek 4300 Bicycle Front Wheel Replacement: 2 단계, 이미지 2/2
    • Unhook the brake wire in the metal tube from the brake wire holder on the brake caliper in your left hand.
  3. Trek 4300 Bicycle Front Wheel Replacement: 3 단계, 이미지 1/1
    • Find the quick release lever located on the bikes fork to loosen the wheel from the frame.
    • Lift the lever from lock position 180 degrees until the open sign on the lever faces outward. Twist the lever while holding the pin on the opposite side of the wheel.
    • The quick release lever does not need to be completely removed.
    • Note which side of the bike the quick release lever is on for proper reassembly.
  4. Trek 4300 Bicycle Front Wheel Replacement: 4 단계, 이미지 1/2 Trek 4300 Bicycle Front Wheel Replacement: 4 단계, 이미지 2/2
    • Pull the frame of the bike upwards to separate the front wheel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erin Ferguson
회원 가입일: 10/13/14
447 평판
안내서 4개 작성하였습니다
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 회원
CLEM-BENSON-F14S3G2
4 회원들
안내서 8개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 2,242
