주요 콘텐츠로 건너뛰기
Trek 4300 Bicycle Kickstand Replacement
필요한 것
  1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: 1 단계, 이미지 1/2 Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: 1 단계, 이미지 2/2
    • Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
    • Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
    • This may require a moderate amount of strength. Make sure you have the proper hex adapter as to not strip the bolt.
  2. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: 2 단계, 이미지 1/2 Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: 2 단계, 이미지 2/2
    • Once the bolt is loose, unscrew it the rest of the way by hand.
    • Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
    • Make sure to note the position of the bracket before you remove the bolt completely
결론
To replace the new kickstand, follow these instructions in reverse order.
Emily OConnor
회원 가입일: 10/13/14
500 평판
안내서 4개 작성하였습니다
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 회원
CLEM-BENSON-F14S3G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 2,767
