주요 콘텐츠로 건너뛰기
Trek 4300 Bicycle Rear Wheel Replacement
  1. Trek 4300 Bicycle Rear Wheel Replacement, Rear Wheel: 1 단계, 이미지 1/1
    • Stand behind your bike straddling the rear wheel and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them towards one another.
  2. Trek 4300 Bicycle Rear Wheel Replacement: 2 단계, 이미지 1/2 Trek 4300 Bicycle Rear Wheel Replacement: 2 단계, 이미지 2/2
    • Unhook the brake wire in the metal tube from the brake wire holder on the caliper in your left hand.
  3. Trek 4300 Bicycle Rear Wheel Replacement: 3 단계, 이미지 1/2 Trek 4300 Bicycle Rear Wheel Replacement: 3 단계, 이미지 2/2
    • Find the quick release lever located on the wheel's fork.
    • Open the leaver 180 degrees from the locked position.
    • Spin the lever counterclockwise a few turns to loosen the pin while holding the opposite of the pin.
  4. Trek 4300 Bicycle Rear Wheel Replacement: 4 단계, 이미지 1/2 Trek 4300 Bicycle Rear Wheel Replacement: 4 단계, 이미지 2/2
    • Pull the bike frame upward off the wheel fork to separate it from the rear wheel.
    • Remove the bottom chain from around the rear cassette on the wheel.
  5. Trek 4300 Bicycle Rear Wheel Replacement: 5 단계, 이미지 1/1
    • In reassembly, lay the top chain on the lowest gear on the rear cassette. Then follow the steps in reverse order beginning with step 3.
결론
To reassemble your device, lay the top chain on the smallest gear of the rear cassette and then follow the steps in reverse order beginning with step 3.
다른 한 분이 해당 안내서를 완성하였습니다.
Emily OConnor
회원 가입일: 10/13/14
500 평판
안내서 4개 작성하였습니다
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 회원
CLEM-BENSON-F14S3G2
4 회원들
안내서 8개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 2,873
