주요 콘텐츠로 건너뛰기
Trek 820 Tail Light Mounting Bracket Replacement
필요한 것
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: 1 단계, 이미지 1개 중 1개
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: 2 단계, 이미지 1개 중 1개
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: 3 단계, 이미지 2개 중 1개 Trek 820 Tail Light Mounting Bracket Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: 4 단계, 이미지 2개 중 1개 Trek 820 Tail Light Mounting Bracket Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
결론
작성자
6다른 기여자 명과 함께
Kaveh Karimiyanha
회원 가입일: 09/24/12
813 평판
안내서 7개를 작성함
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G1
5 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 1,215
