이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Wrap the mounting bracket strap around the seat post.
Verify the larger piece rests towards the tail end aligned with the tires.
Verify the bracket's screw hole is on the right side of the bicycle.
Locate the slot on the bracket where the strap will be inserted.
Insert the strap into the slot.
Tighten the strap just enough to keep the bracket in place.
Insert the screw into the bracket screw hole.
Tighten the screw with fingers until the mounting bracket rests freely on seat post.
