주요 콘텐츠로 건너뛰기
Trek FX2 Fitness Bike Saddle Replacement
필요한 것
  1. Trek FX2 Fitness Bike Saddle Replacement, Saddle: 1 단계, 이미지 3개 중 1개 Trek FX2 Fitness Bike Saddle Replacement, Saddle: 1 단계, 이미지 3개 중 2개 Trek FX2 Fitness Bike Saddle Replacement, Saddle: 1 단계, 이미지 3개 중 3개
    • Locate the bolt under the saddle.
    • Use a 5mm Allen Wrench to loosen and remove the M8x30 mm bolt.
    • Remove the saddle from under the plate.
  2. Trek FX2 Fitness Bike Saddle Replacement: 2 단계, 이미지 2개 중 1개 Trek FX2 Fitness Bike Saddle Replacement: 2 단계, 이미지 2개 중 2개
    • Use a towel covered in isopropyl rubbing alcohol to clean any dirt from the bolts and plate.
  3. Trek FX2 Fitness Bike Saddle Replacement: 3 단계, 이미지 2개 중 1개 Trek FX2 Fitness Bike Saddle Replacement: 3 단계, 이미지 2개 중 2개
    • Apply Finish Line Premium Grease to the bolt.
    • Work the grease around the threads.
  4. Trek FX2 Fitness Bike Saddle Replacement: 4 단계, 이미지 3개 중 1개 Trek FX2 Fitness Bike Saddle Replacement: 4 단계, 이미지 3개 중 2개 Trek FX2 Fitness Bike Saddle Replacement: 4 단계, 이미지 3개 중 3개
    • Clean the replacement bicycle saddle with a towel and isopropyl alcohol.
  5. Trek FX2 Fitness Bike Saddle Replacement: 5 단계, 이미지 2개 중 1개 Trek FX2 Fitness Bike Saddle Replacement: 5 단계, 이미지 2개 중 2개
    • Apply Finish Line Premium Grease to the rails of the bicycle saddle.
  6. Trek FX2 Fitness Bike Saddle Replacement: 6 단계, 이미지 3개 중 1개 Trek FX2 Fitness Bike Saddle Replacement: 6 단계, 이미지 3개 중 2개 Trek FX2 Fitness Bike Saddle Replacement: 6 단계, 이미지 3개 중 3개
    • Align the seat rails with the channels in the saddle plate.
    • Slide the rails into the channels of the saddle plate.
    • Adjust the seat position to your preference.
  7. Trek FX2 Fitness Bike Saddle Replacement: 7 단계, 이미지 3개 중 1개 Trek FX2 Fitness Bike Saddle Replacement: 7 단계, 이미지 3개 중 2개 Trek FX2 Fitness Bike Saddle Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the bolts into the holes on the saddle plate.
    • Tighten the bolts by hand until they are snug.
    • Use an Allen wrench to evenly tighten the bolts.
  8. Trek FX2 Fitness Bike Saddle Replacement: 8 단계, 이미지 1개 중 1개
    • Sit on the seat to check its angle and stability.
결론
Test out the bike seat, and adjust accordingly.
작성자
3다른 기여자 명과 함께
David Fong
회원 가입일: 11/05/24
157 평판
안내서 1개를 작성함
UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S4G6
3 회원들
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 85
