주요 콘텐츠로 건너뛰기
Trek Mountain Bike Derailleur Hanger Replacement
필요한 것
  1. Trek Mountain Bike Derailleur Hanger Replacement, Select hanger: 1 단계, 이미지 1개 중 1개
    • Be sure to select the correct hanger for your bike, as there is very little substitutability between brands and models.
    • Find the correct hanger for your bike by contacting the manufacturer, or by using an online database such as derailleurhanger.com.
  2. Trek Mountain Bike Derailleur Hanger Replacement, Remove wheel: 2 단계, 이미지 1개 중 1개
    • Remove the wheel and set it to the side.
  3. Trek Mountain Bike Derailleur Hanger Replacement, Remove derailleur: 3 단계, 이미지 1개 중 1개
    • Remember the fastener orientation on the hanger when removing it from the frame.
    • Keep the fasteners if they are in good condition, as they are not always included with new replacement hangers.
  4. Trek Mountain Bike Derailleur Hanger Replacement, Install wheel: 4 단계, 이미지 1개 중 1개
    • After installing the wheel, remember to clamp the wheel tightly in the frame. This secures the hanger in place.
    • Check the hanger alignment with the DAG-3 Derailleur Hanger Alignment Gauge.
  5. Trek Mountain Bike Derailleur Hanger Replacement, Install derailleur: 5 단계, 이미지 1개 중 1개
    • If there is a lot of resistance when threading the derailleur back on, the threads might be worn down. It is then recommended to replace the threads on your derailleur.
    • Double check the shifting performance of your bike, making sure it is functioning properly.
결론
The derailleur hanger should now be custom-fitted to your bike, allowing for smooth and functioning shifting.
작성자
1다른 기여자 명과 함께
Drew
회원 가입일: 11/07/23
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 277
