주요 콘텐츠로 건너뛰기
Triace A310 Brake Cable Replacement
필요한 것
  1. Triace A310 Brake Cable Replacement, Brake Cable: 1 단계, 이미지 2개 중 1개 Triace A310 Brake Cable Replacement, Brake Cable: 1 단계, 이미지 2개 중 2개
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: 2 단계, 이미지 3개 중 1개 Triace A310 Brake Cable Replacement: 2 단계, 이미지 3개 중 2개 Triace A310 Brake Cable Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: 3 단계, 이미지 2개 중 1개 Triace A310 Brake Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: 4 단계, 이미지 3개 중 1개 Triace A310 Brake Cable Replacement: 4 단계, 이미지 3개 중 2개 Triace A310 Brake Cable Replacement: 4 단계, 이미지 3개 중 3개
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: 5 단계, 이미지 3개 중 1개 Triace A310 Brake Cable Replacement: 5 단계, 이미지 3개 중 2개 Triace A310 Brake Cable Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
결론
To place the new cable, follow these instructions in reverse order.
작성자
6다른 기여자 명과 함께
Ben Hartinger
회원 가입일: 01/27/14
340 평판
안내서 3개를 작성함
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 회원
CPSU-MANESS-W14S1G37
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 425
