주요 콘텐츠로 건너뛰기
Triace A310 Brake Pad Replacement
필요한 것
  1. Triace A310 Brake Pad Replacement, Brake Pad: 1 단계, 이미지 2개 중 1개 Triace A310 Brake Pad Replacement, Brake Pad: 1 단계, 이미지 2개 중 2개
    • Note: In this repair guide the pictures are taken with the tire removed so that it is easier to follow our steps. However, removing the tire is not necessary to replace the brake pads.
    • Unscrew the brake pad cap with a T25 screwdriver bit.
  2. Triace A310 Brake Pad Replacement: 2 단계, 이미지 3개 중 1개 Triace A310 Brake Pad Replacement: 2 단계, 이미지 3개 중 2개 Triace A310 Brake Pad Replacement: 2 단계, 이미지 3개 중 3개
    • Grab and pull out the spring between the brake pads.
  3. Triace A310 Brake Pad Replacement: 3 단계, 이미지 3개 중 1개 Triace A310 Brake Pad Replacement: 3 단계, 이미지 3개 중 2개 Triace A310 Brake Pad Replacement: 3 단계, 이미지 3개 중 3개
    • Slide out the back brake pad first. Then slide out the front brake pad.
  4. Triace A310 Brake Pad Replacement: 4 단계, 이미지 2개 중 1개 Triace A310 Brake Pad Replacement: 4 단계, 이미지 2개 중 2개
    • Slide in the new brake pads with the first going in the front.
  5. Triace A310 Brake Pad Replacement: 5 단계, 이미지 3개 중 1개 Triace A310 Brake Pad Replacement: 5 단계, 이미지 3개 중 2개 Triace A310 Brake Pad Replacement: 5 단계, 이미지 3개 중 3개
    • Then slide in the other pad in the back.
    • Make sure each brake pad is facing the right way.
  6. Triace A310 Brake Pad Replacement: 6 단계, 이미지 3개 중 1개 Triace A310 Brake Pad Replacement: 6 단계, 이미지 3개 중 2개 Triace A310 Brake Pad Replacement: 6 단계, 이미지 3개 중 3개
    • Push the spring back into place between the two brake pads so the spring is visible in the hole shown here.
  7. Triace A310 Brake Pad Replacement: 7 단계, 이미지 2개 중 1개 Triace A310 Brake Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Screw the brake pad cap back on.
  8. Triace A310 Brake Pad Replacement: 8 단계, 이미지 1개 중 1개
    • Adjust the red knob as necessary (directions are noted on the knob).
    • Be sure to test your brakes thoroughly in a safe, low-speed environment.
결론
Now your bike should actually be able to stop.
작성자
4다른 기여자 명과 함께
Ben Hartinger
회원 가입일: 01/27/14
340 평판
안내서 3개를 작성함
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 회원
CPSU-MANESS-W14S1G37
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 416
