주요 콘텐츠로 건너뛰기
Triace A310 Disk Brake Replacement
필요한 것
  1. Triace A310 Disk Brake Replacement, Tire: 1 단계, 이미지 1개 중 1개
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Disk Brake Replacement: 2 단계, 이미지 2개 중 1개 Triace A310 Disk Brake Replacement: 2 단계, 이미지 2개 중 2개
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Disk Brake Replacement: 3 단계, 이미지 2개 중 1개 Triace A310 Disk Brake Replacement: 3 단계, 이미지 2개 중 2개
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Disk Brake Replacement, Disk Brake: 4 단계, 이미지 1개 중 1개
    • Place the tire flat on the ground making sure the disk is facing you.
  5. Triace A310 Disk Brake Replacement: 5 단계, 이미지 3개 중 1개 Triace A310 Disk Brake Replacement: 5 단계, 이미지 3개 중 2개 Triace A310 Disk Brake Replacement: 5 단계, 이미지 3개 중 3개
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  6. Triace A310 Disk Brake Replacement: 6 단계, 이미지 2개 중 1개 Triace A310 Disk Brake Replacement: 6 단계, 이미지 2개 중 2개
    • After all of the screws have been removed, take the disk and pull it away from the tire.
결론
작성자
6다른 기여자 명과 함께
Daniel
회원 가입일: 01/27/14
222 평판
안내서 2개를 작성함
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 회원
CPSU-MANESS-W14S1G37
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 5
전체 시간: 646
