소개
This guide will help you replace the batteries of your Tribit X Sound Go speaker.
Note: There might be a swollen battery or battery acid, please use caution.
필요한 것
Insert a spudger in the seam between the front speaker grill and chassis.
Pry around the perimeter until the front grill releases.
Remove the front grill.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Same here. What is the replacement battery number?
