주요 콘텐츠로 건너뛰기
Tribit XSound Go TS-BTS20 Passive Radiator Replacement
필요한 것
  1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: 1 단계, 이미지 1/2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: 1 단계, 이미지 2/2
    • Insert a spudger in the seam between the front speaker grill and chassis.
    • Pry around the perimeter until the front grill releases.
    • Remove the front grill.
  2. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: 2 단계, 이미지 1/1
    • Unscrew all the screws with the Phillips screwdriver, on the opened panel.
    • Lift off the speaker housing.
  3. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: 3 단계, 이미지 1/2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement: 3 단계, 이미지 2/2
    • Hold the frame which has the passive radiator in the middle.
  4. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: 4 단계, 이미지 1/1
    • Use a spudger to push the damaged passive radiator off the frame
  5. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: 5 단계, 이미지 1/1
    • Insert the new passive radiator into the frame.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
결론
Hasini Kanuru
회원 가입일: 09/12/23
271 평판
안내서 1개 작성함
University of North Texas, Team 3-3, Coppersmith Fall 2023 University of North Texas, Team 3-3, Coppersmith Fall 2023 회원
UNT-COPPERSMITH-F23S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 64
