주요 콘텐츠로 건너뛰기
Trio AXS 3G Back Case Replacement
필요한 것
  1. Trio AXS 3G Back Case Replacement, Back Case: 1 단계, 이미지 1/1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Back Case Replacement: 2 단계, 이미지 1/2 Trio AXS 3G Back Case Replacement: 2 단계, 이미지 2/2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Back Case Replacement: 3 단계, 이미지 1/1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
결론
Javoy Ross
회원 가입일: 09/20/17
316 평판
안내서 3개 작성하였습니다
University of North Texas, Team S7-G6, Thomas Fall 2017 University of North Texas, Team S7-G6, Thomas Fall 2017 회원
UNT-THOMAS-F17S7G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 346
