주요 콘텐츠로 건너뛰기
Trio STEALTH-9 Camera Replacement
필요한 것
  1. Trio STEALTH-9 Camera Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Camera Replacement: 2 단계, 이미지 1/1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Camera Replacement: 3 단계, 이미지 1/1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Camera Replacement: 4 단계, 이미지 1/1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
  5. Trio STEALTH-9 Camera Replacement, Camera: 5 단계, 이미지 1/2 Trio STEALTH-9 Camera Replacement, Camera: 5 단계, 이미지 2/2
    • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
  6. Trio STEALTH-9 Camera Replacement: 6 단계, 이미지 1/2 Trio STEALTH-9 Camera Replacement: 6 단계, 이미지 2/2
    • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
  7. Trio STEALTH-9 Camera Replacement: 7 단계, 이미지 1/2 Trio STEALTH-9 Camera Replacement: 7 단계, 이미지 2/2
    • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
    • Remove the camera from the frame and replace as needed.
결론
[deleted]
회원 가입일: 01/29/15
415 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 141
