주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trio Stealth G2 Hype Battery Replacement
필요한 것
  1. Trio Stealth G2 Hype Battery Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Trio Stealth G2 Hype Battery Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Battery Replacement: 3 단계, 이미지 3개 중 1개 Trio Stealth G2 Hype Battery Replacement: 3 단계, 이미지 3개 중 2개 Trio Stealth G2 Hype Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Battery Replacement, Speakers: 4 단계, 이미지 2개 중 1개 Trio Stealth G2 Hype Battery Replacement, Speakers: 4 단계, 이미지 2개 중 2개
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Battery Replacement: 5 단계, 이미지 1개 중 1개
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
  6. Trio Stealth G2 Hype Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 Trio Stealth G2 Hype Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • While holding the mother board down, slowly remove the battery from tape on the back of the screen.
    • Make sure to keep all wires attached for now.
  7. Trio Stealth G2 Hype Battery Replacement: 7 단계, 이미지 1개 중 1개
    • In order to replace the battery once the wires are removed, you will need to solder the wires of the new battery onto the motherboard.
    • The red wire must be soldered to the "+" terminal while the black is soldered to the "-" terminal.
    • Pull the wires off the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Thomas Lichtenberger
회원 가입일: 01/21/15
459 평판
안내서 3개를 작성함
USF Tampa, Team 4-4, Brown Winter 2015 USF Tampa, Team 4-4, Brown Winter 2015 회원
USFT-BROWN-W15S4G4
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 32
전체 시간: 2,481
