주요 콘텐츠로 건너뛰기
Trio Stealth G2 Hype Speakers Replacement
필요한 것
  1. Trio Stealth G2 Hype Speakers Replacement, Back Panel: 1 단계, 이미지 1/2 Trio Stealth G2 Hype Speakers Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Speakers Replacement: 2 단계, 이미지 1/1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Speakers Replacement: 3 단계, 이미지 1/3 Trio Stealth G2 Hype Speakers Replacement: 3 단계, 이미지 2/3 Trio Stealth G2 Hype Speakers Replacement: 3 단계, 이미지 3/3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Speakers Replacement, Speakers: 4 단계, 이미지 1/2 Trio Stealth G2 Hype Speakers Replacement, Speakers: 4 단계, 이미지 2/2
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Speakers Replacement: 5 단계, 이미지 1/1
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
결론
Thomas Lichtenberger
회원 가입일: 01/21/15
459 평판
안내서 3개 작성하였습니다
USF Tampa, Team 4-4, Brown Winter 2015 USF Tampa, Team 4-4, Brown Winter 2015 회원
USFT-BROWN-W15S4G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 220
