주요 콘텐츠로 건너뛰기
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
필요한 것
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: 1 단계, 이미지 1/1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: 2 단계, 이미지 1/1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: 3 단계, 이미지 1/1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: 4 단계, 이미지 1/1
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: 5 단계, 이미지 1/1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Coleman
회원 가입일: 10/29/15
643 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 회원
UMASSD-MILES-F15S1G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 409
