주요 콘텐츠로 건너뛰기
Triplett ET200 AC Line Splitter Basic Outlet testing.
  1. Triplett ET200 AC Line Splitter Basic Outlet testing., Triplett ET200 AC Line Splitter Basic Outlet testing.: 1 단계, 이미지 3개 중 1개 Triplett ET200 AC Line Splitter Basic Outlet testing., Triplett ET200 AC Line Splitter Basic Outlet testing.: 1 단계, 이미지 3개 중 2개 Triplett ET200 AC Line Splitter Basic Outlet testing., Triplett ET200 AC Line Splitter Basic Outlet testing.: 1 단계, 이미지 3개 중 3개
    • To check outlet wiring, we use the chart on the back and this device works like any other outlet tester
    • Plug the device in and read the lights based on the chart. (Please note that in my image, the actual test shows the normal lights on the right verses the left as reading the chart. This is due to the outlet orientation)
    • If you get the 2 orange lights, then your outlet is wired correctly. Otherwise if you have different or no lights, see the chart for where to look for the problem.
    • You are done testing your outlet. If your outlet is not correct, please do not try to correct it without a good understanding of house wiring standards and make sure to turn the power off before opening up an outlet.
결론
Testing your home outlets is easy with the correct electric testers.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
rickwag
회원 가입일: 10/18/10
1,602 평판
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 90
