주요 콘텐츠로 건너뛰기
Tristar Handmixer Gears Replacement
필요한 것
  1. Tristar Handmixer Gears Replacement, Gears: 1 단계, 이미지 1/3 Tristar Handmixer Gears Replacement, Gears: 1 단계, 이미지 2/3 Tristar Handmixer Gears Replacement, Gears: 1 단계, 이미지 3/3
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: 2 단계, 이미지 1/3 Tristar Handmixer Gears Replacement: 2 단계, 이미지 2/3 Tristar Handmixer Gears Replacement: 2 단계, 이미지 3/3
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: 3 단계, 이미지 1/3 Tristar Handmixer Gears Replacement: 3 단계, 이미지 2/3 Tristar Handmixer Gears Replacement: 3 단계, 이미지 3/3
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: 4 단계, 이미지 1/2 Tristar Handmixer Gears Replacement: 4 단계, 이미지 2/2
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: 5 단계, 이미지 1/1
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
njjong
회원 가입일: 12/05/16
25 평판
안내서 1개 작성함
댓글 2개
where can I get replacement gears from?
lanz - 답글
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 26
전체 시간: 1,453
