주요 콘텐츠로 건너뛰기
Tritton Kunai Right Speaker Replacement
필요한 것
  1. Tritton Kunai Right Speaker Replacement, Right Speaker: 1 단계, 이미지 2개 중 1개 Tritton Kunai Right Speaker Replacement, Right Speaker: 1 단계, 이미지 2개 중 2개
    • Firmly grasp the black ear cushion with one hand and the white speaker frame with the other hand.
    • Forcibly pull the ear cushion and speaker frame in opposite directions, until the right ear cushion separates from the right ear frame.
  2. Tritton Kunai Right Speaker Replacement: 2 단계, 이미지 2개 중 1개 Tritton Kunai Right Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 9 mm screws indicated in red with a PH00 screwdriver.
    • Remove the two 7 mm screws indicated in orange with a PH00 screwdriver.
    • Separate the black horseshoe shaped frame from the right speaker frame.
  3. Tritton Kunai Right Speaker Replacement: 3 단계, 이미지 2개 중 1개 Tritton Kunai Right Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black bracket and then the rail adjustment from the right speaker frame.
  4. Tritton Kunai Right Speaker Replacement: 4 단계, 이미지 2개 중 1개 Tritton Kunai Right Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the five 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black speaker console from the right speaker frame.
  5. Tritton Kunai Right Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the red and green wires from the 16 Ohm speaker.
  6. Tritton Kunai Right Speaker Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Squeeze the tip of the tweezers into the gap between the speaker and the speaker case.
    • Remove the glue holding the speaker in place by scraping the glue with the tip of the tweezers.
  7. Tritton Kunai Right Speaker Replacement: 7 단계, 이미지 2개 중 1개 Tritton Kunai Right Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the speaker from its circular shaped slot.
    • Apply glue to the sides of your new 16 Ohm speaker.
  8. Tritton Kunai Right Speaker Replacement: 9 단계, 이미지 2개 중 1개 Tritton Kunai Right Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Insert your new speaker into the circular shaped slot located on the speaker cover.
  9. Tritton Kunai Right Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Solder the wires you disconnected from the old speaker to the new speaker. The red wire is to be soldered to the far right terminal, while the green wire is to be soldered to the far left terminal.
    • Here is iFixit's soldering guide.
    • Solder with caution and try not to burn yourself.
결론
To reassemble your device, follow steps 1 through 4 in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Elias El Tom
회원 가입일: 03/12/15
338 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-3, Duarte Spring 2015 UMass Dartmouth, Team 3-3, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G3
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 14
전체 시간: 1,155
