주요 콘텐츠로 건너뛰기
Troy-Bilt TB675 EC Air Filter Replacement
필요한 것
  1. Troy-Bilt TB675 EC Air Filter Replacement, Air Filter: 1 단계, 이미지 1/1
    • Remove the air filter housing by turning the plastic screw counterclockwise with your hand.
  2. Troy-Bilt TB675 EC Air Filter Replacement, Remove the air filter that lays beneath the housing you removed in step 1: 2 단계, 이미지 1/1
    • Remove the air filter that lays beneath the housing you removed in step 1.
    • It is good practice to inspect your air filter for tears or other defects. If defects are found it is best to replace the air filter rather than to clean it.
  3. Troy-Bilt TB675 EC Air Filter Replacement: 3 단계, 이미지 1/1
    • Clean the air filter thoroughly by spraying compressed air through the filter.
    • Be sure to spray the compressed air away from you in order to prevent injury.
  4. Troy-Bilt TB675 EC Air Filter Replacement: 4 단계, 이미지 1/2 Troy-Bilt TB675 EC Air Filter Replacement: 4 단계, 이미지 2/2
    • Wipe all oil and water residue around the air filter casing with a paper towel or rag.
  5. Troy-Bilt TB675 EC Air Filter Replacement: 5 단계, 이미지 1/1
    • Place the air filter and air filter casing back in its original position.
    • Be sure the air filter and housing are lined up correctly.
  6. Troy-Bilt TB675 EC Air Filter Replacement: 6 단계, 이미지 1/1
    • Complete the maintenance by turning the screw clockwise with your hand until it is fully secured.
결승점
Brian Hall
회원 가입일: 10/10/14
110 평판
안내서 1개 작성함
USF Tampa, Team 1-10, Donnelly Fall 2014 USF Tampa, Team 1-10, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G10
1 회원
안내서 1개 작성하였습니다
댓글 한 개
I believe you may have missed the small detail of giving us a part #.
That would’ve been VERY helpful.
Mark Henry Cooney - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 37
전체 시간: 2,387
