주요 콘텐츠로 건너뛰기
Tungsten E Battery Replacement
필요한 것
  1. Tungsten E Battery Replacement, Battery: 1 단계, 이미지 1/1
  2. Tungsten E Battery Replacement: 2 단계, 이미지 1/1
    • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
    • Caution: the battery is connected by two wires.
  3. Tungsten E Battery Replacement: 3 단계, 이미지 1/1
    • Remove the battery
    • Caution: Be careful not to tear the wires when removing battery.
  4. Tungsten E Battery Replacement: 4 단계, 이미지 1/1
    • Using a soldering iron, disconnect the battery wires.
    • Note: the wires are soldered to the board.
  5. Tungsten E Battery Replacement: 5 단계, 이미지 1/1
    • Take replacement battery and solder the wires to the board.
    • Take care to match wire colors as before.
    • Use double sided tape to attach battery firmly to board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kathleen Hix
회원 가입일: 01/21/10
49 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 회원
CPSU-MANESS-W10S13G22
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 6,695
