주요 콘텐츠로 건너뛰기
Tungsten E Disassembly
필요한 것
  1. Tungsten E Disassembly, Tungsten E Disassembly: 1 단계, 이미지 1/2 Tungsten E Disassembly, Tungsten E Disassembly: 1 단계, 이미지 2/2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: 2 단계, 이미지 1/3 Tungsten E Disassembly: 2 단계, 이미지 2/3 Tungsten E Disassembly: 2 단계, 이미지 3/3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
    I think it's better to open from the right, not the left. The right will separate if you lever the metal back to the outside and push the plastic to the inside. The lft is more like a inge and would damage more easily.
    Just my $0.02.
    Yishai Sered - 답글
  3. Tungsten E Disassembly: 3 단계, 이미지 1/2 Tungsten E Disassembly: 3 단계, 이미지 2/2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: 4 단계, 이미지 1/2 Tungsten E Disassembly: 4 단계, 이미지 2/2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: 5 단계, 이미지 1/3 Tungsten E Disassembly: 5 단계, 이미지 2/3 Tungsten E Disassembly: 5 단계, 이미지 3/3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: 6 단계, 이미지 1/1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
결론
Kevin Hom
회원 가입일: 01/21/10
103 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 회원
CPSU-MANESS-W10S13G22
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
How does one unplug the battery?
dlcatftwin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 7,789
