주요 콘텐츠로 건너뛰기
Turning off the center dashboard displays
  1. Turning off the center dashboard displays, Turning off the center dashboard displays: 1 단계, 이미지 1/3 Turning off the center dashboard displays, Turning off the center dashboard displays: 1 단계, 이미지 2/3 Turning off the center dashboard displays, Turning off the center dashboard displays: 1 단계, 이미지 3/3
    • :Press and hold the CD/AUX button on the base model stereo head unit for 10 seconds.
    • A beep will sound.
    • The clock, radio display, and heating/cooling displays turn off. Console backlighting remains on. Their functions are still active: you can change channels, adjust climate control. The displays are simply disabled.
    • To turn the displays back on, repeat step 1.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
David Spalding
회원 가입일: 11/12/15
6,470 평판
안내서 12개 작성하였습니다
댓글 한 개
Do you know which button is used to turn off display in second generation Acura TSX?
Vinod R - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 4,340
