주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force Stealth 500P Battery Replacement
필요한 것
  1. Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 1 단계, 이미지 1/3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 1 단계, 이미지 2/3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 1 단계, 이미지 3/3
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
  2. Turtle Beach Ear Force Stealth 500P Battery Replacement: 2 단계, 이미지 1/2 Turtle Beach Ear Force Stealth 500P Battery Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
  3. Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 3 단계, 이미지 1/3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 3 단계, 이미지 2/3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Use screwdriver tip J00 to remove three screws fastening circuit board to casing.
  4. Turtle Beach Ear Force Stealth 500P Battery Replacement: 4 단계, 이미지 1/2 Turtle Beach Ear Force Stealth 500P Battery Replacement: 4 단계, 이미지 2/2
    • Use bent tweezers to remove two wire connector plugs from circuit board.
  5. Turtle Beach Ear Force Stealth 500P Battery Replacement: 5 단계, 이미지 1/2 Turtle Beach Ear Force Stealth 500P Battery Replacement: 5 단계, 이미지 2/2
    • Circuit board will be free to be removed by hand. Use plastic pry tool to slide between casing and circuit board if needed.
  6. Turtle Beach Ear Force Stealth 500P Battery Replacement: 6 단계, 이미지 1/1
    • Gently removed and flip over circuit board to reveal battery pack attached to the underside. Careful not to pull out wires running through headband.
  7. Turtle Beach Ear Force Stealth 500P Battery Replacement: 7 단계, 이미지 1/1
    • Use metal pry tool to slide between battery and circuit board to break up adhesive. Ensure the battery wire connector plug has been removed on front side.
  8. Turtle Beach Ear Force Stealth 500P Battery Replacement: 8 단계, 이미지 1/1
    • Battery will be free to be removed and replaced.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Noah Franklin
회원 가입일: 10/27/15
445 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-3, Shastany Fall 2015 UMass Dartmouth, Team 2-3, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S2G3
3 회원들
안내서 10개 작성하였습니다
댓글 3개
Where can I get a replacement battery?
Jeremy Nocek - 답글
You can look on Ebay or Amazon. You can find it by searching the model number: ( FT603048P )
The costs are like $20-$30.
If you look on Ebay under: ( 3.7v 603048 ), you can get the same battery without the connector for like $5.
William Smith - 답글
hey i have a question, how i can repair the mute button? It does not work.
fiercecesar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 41
전체 시간: 23,707
