주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force X12 Ear Pads Replacement
  1. Turtle Beach Ear Force X12 Ear Pads Replacement, Ear Pads: 1 단계, 이미지 1개 중 1개
    • Start by removing the left ear pad.
    • Gently pull on the pad from the side by the leathery material until it comes loose from slot.
    • Be careful not to rip the fabric.
  2. Turtle Beach Ear Force X12 Ear Pads Replacement: 2 단계, 이미지 1개 중 1개
    • Grip ear cushion and carefully pull up and separate from the plastic headphone.
  3. Turtle Beach Ear Force X12 Ear Pads Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Ear Force X12 Ear Pads Replacement: 3 단계, 이미지 2개 중 2개
    • Your headset should look like the first picture, with the left cushion removed.
    • Repeat these steps for right cushion.
    • You may now continue with more complex inner headset repair, or replace the ear pads by sliding on new ones in the slot.
결론
To reassemble your device, slip on new cushions
작성자
5다른 기여자 명과 함께
Katha Patel
회원 가입일: 10/02/17
218 평판
안내서 2개를 작성함
USF Tampa, Team S1-G3, Thompson Fall 2017 USF Tampa, Team S1-G3, Thompson Fall 2017 회원
USFT-THOMPSON-F17S1G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 1,483
