주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force XO One Adapter Buttons Replacement
필요한 것
  1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: 1 단계, 이미지 1/1
    • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
    • The recommended screwdriver bit size is a PH 000.
  2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: 2 단계, 이미지 1/1
    • Using your hands and/or a prying tool, carefully pry open the adapter.
    • This step may require a bit of force to complete.
    • Be aware that the adapter is held together with clips on the inside at some locations.
    • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
  3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: 3 단계, 이미지 1/3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: 3 단계, 이미지 2/3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: 3 단계, 이미지 3/3
    • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
    • Once the screws are out, you can remove the circuit board from the casing.
  4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: 4 단계, 이미지 1/1
    • Push the rubber piece containing the buttons out of the plastic adapter casing.
    • Then, replace it with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Lane
회원 가입일: 10/27/15
128 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-1, Shastany Fall 2015 UMass Dartmouth, Team 3-1, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S3G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,582
