주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement
필요한 것
  1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: 1 단계, 이미지 2개 중 1개 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: 1 단계, 이미지 2개 중 2개
    • The microphone is a separate piece. So, unplug it from the headset.
  2. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: 2 단계, 이미지 2개 중 1개 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: 2 단계, 이미지 2개 중 2개
    • Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
  3. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: 3 단계, 이미지 3개 중 1개 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: 3 단계, 이미지 3개 중 2개 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: 3 단계, 이미지 3개 중 3개
    • Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
    • Then slide the windscreen off of the microphone.
결론
작성자
5다른 기여자 명과 함께
Andrew Rudnick
회원 가입일: 01/31/15
281 평판
안내서 2개를 작성함
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G36
4 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 19
전체 시간: 2,786
