소개
This guide will teach you how to remove the side plate from the headset. You can use a metal spudger or your fingernail to remove the side plate. If you decide to use your fingernail, be warned that it will be a bit more difficult.
필요한 것
Find the small notch on the side (left or right) of the side plate.
Insert the metal spudger into the notch.
거의 끝나갑니다!
To put the side plate back, simply snap the side plate into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
