주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
필요한 것
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: 1 단계, 이미지 2개 중 1개 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: 1 단계, 이미지 2개 중 2개
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: 2 단계, 이미지 2개 중 1개 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: 2 단계, 이미지 2개 중 2개
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nancy Truong
회원 가입일: 01/30/15
375 평판
안내서 2개를 작성함
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G36
4 회원들
안내서 12개를 작성함
댓글 7개
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - 답글
I really don't want to buy another turtle beach headset
jamesfalduto - 답글
James did you ever find a solution because I have the same problem
Commandcorps - 답글
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 4,393
