주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force XO Seven Speaker Cone Replacement
필요한 것
  1. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: 1 단계, 이미지 1/2 Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Ear Pad: 1 단계, 이미지 2/2
    • Begin by placing your thumb on the plastic edge around the ear pad.
    • Get a good grip around the ear pad and gently separate it from the headset.
    • Apply the same instructions to remove the other foam pad off of the headset.
    • Make sure you continue to gently peel the ear pad from the headset until completely removed.
  2. Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: 3 단계, 이미지 1/2 Turtle Beach Ear Force XO Seven Speaker Cone Replacement, Speaker Cone: 3 단계, 이미지 2/2
    • A new speaker cone for these headphones will cost about $8 to $10 from amazon.com.
    • After removing the ear pads, unscrew the four Phillips head screws that hold the front plate on.
    • To avoid losing small screws, place them in a container.
  3. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: 4 단계, 이미지 1/2 Turtle Beach Ear Force XO Seven Speaker Cone Replacement: 4 단계, 이미지 2/2
    • When removing the speaker cone plate, be careful not to drop it or put stress on the wires as they are very delicate.
    • Remove the speaker cone plate on a flat surface to prevent unnecessary stress on the wires.
    • The speaker cone is attached to the front plate. To replace, unsolder the wires from the two connection points.
  4. Turtle Beach Ear Force XO Seven Speaker Cone Replacement: 5 단계, 이미지 1/1
    • Replace the speaker cone carefully in place of the old one.
    • Consider tinning the wires before soldering them on to the new speaker cone.
    • Solder the wires back on to the new speaker cone.
    • Reassemble the front plate.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jacob
회원 가입일: 01/31/15
166 평판
안내서 1개 작성함
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G36
4 회원들
안내서 12개 작성하였습니다
댓글 3개
I couldn't find the speaker cone at amazon. Does anyone have a link?
victorlborges - 답글
You need to buy a Broken Headset the use that to replace the speaker.
Andy Millett - 답글
Is there anywhere that i can buy replacement swivel part that hold the speaker
Robert bee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 5,544
