주요 콘텐츠로 건너뛰기
Turtle Beach Elite 800 Charging Pins on Headset Replacement
필요한 것
  1. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: 1 단계, 이미지 2개 중 1개 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: 1 단계, 이미지 2개 중 2개
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: 2 단계, 이미지 2개 중 1개 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screw bit to remove the four screws (9.47 mm long) that have been revealed from removing the ear cup. Carefully take off the blue casing to reveal the audio board.
  3. Turtle Beach Elite 800 Charging Pins on Headset Replacement: 3 단계, 이미지 3개 중 1개 Turtle Beach Elite 800 Charging Pins on Headset Replacement: 3 단계, 이미지 3개 중 2개 Turtle Beach Elite 800 Charging Pins on Headset Replacement: 3 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screw bit to remove the two screws (7.92 mm long) that are holding the contact pins in place.
    • Then, simply push the pins from the board.
결론
작성자
1다른 기여자 명과 함께
Johnny Lofton
회원 가입일: 01/18/17
861 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 1,003
