필요한 것
To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
댓글 4개
My left earcup unclipped where it rotates and doesn’t want to clip back in properly,how do I fix this?
Are Elite 800 ear pads going to fit Elite 800x headset? Im from UK and I cant find pads for 800x anywhere.
It’s the same pair of headsets, only the dock is different, so yes it will fit. Please let me know if you find any ear pads that come with the plastic part, i could not find any :(
I have tested this solution works as harm. https://youtu.be/0HVYC6ao8Qs
Kasia Bura - 답글
