주요 콘텐츠로 건너뛰기
Turtle Beach Elite Pro Headband Replacement
필요한 것
  1. Turtle Beach Elite Pro Headband Replacement, Headband: 1 단계, 이미지 1/2 Turtle Beach Elite Pro Headband Replacement, Headband: 1 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the three 4.5 mm screws from the adjustment plate on both the left and right side.
    • When reassembling the headband, make sure the left and right sides of the headband line up with their respective designations.
  2. Turtle Beach Elite Pro Headband Replacement: 2 단계, 이미지 1/2 Turtle Beach Elite Pro Headband Replacement: 2 단계, 이미지 2/2
    • Lift the headband from the headset and replace with the new one.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alexis Uribe
회원 가입일: 03/24/17
510 평판
안내서 4개 작성하였습니다
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G1
3 회원들
안내서 8개 작성하였습니다
댓글 10개
Where did you buy the piece to replace
Audiz - 답글
I need you urgently, please
Audiz - 답글
I need the hand band where can u buy one
Anthony Lara - 답글
I need that headband piece as well! Where do you buy it?
Imanol Caba - 답글
Where can I buy the replacement headband.
loged45 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 21
전체 시간: 7,351
