주요 콘텐츠로 건너뛰기
Turtle Beach Elite Pro Right Speaker Replacement
필요한 것
  1. Turtle Beach Elite Pro Right Speaker Replacement, Ear Cushions: 1 단계, 이미지 1개 중 1개
    • Firmly pinch ear cushion between thumb and forefinger.
    • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
    • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
  2. Turtle Beach Elite Pro Right Speaker Replacement: 2 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Right Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Rotate ear cushion counter-clockwise about half an inch.
    • The ear cushion should audibly snap out of place.
    • After it has audibly snapped out of place, lift the ear cushion off of the device.
    • During reassembly, rotate the ear cushion clockwise.
  3. Turtle Beach Elite Pro Right Speaker Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Right Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
    • Make sure that both the ear cushion and the orange plate have the same designation.
    • Once the pegs are aligned, push the new ear cushion in place.
  4. Turtle Beach Elite Pro Right Speaker Replacement, Right Speaker: 4 단계, 이미지 1개 중 1개
    • Remove the right ear cushion.
    • The right ear piece does not have any additional attachments.
  5. Turtle Beach Elite Pro Right Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
  6. Turtle Beach Elite Pro Right Speaker Replacement: 6 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Right Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Use the opening tool to separate the orange plate from the black base plate.
    • Focus on the wires that are connected to the speaker.
  7. Turtle Beach Elite Pro Right Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Cut the two wires that are attached to the speaker.
    • Cut the wires as close to the speaker as possible. These wires will be used in the next step.
  8. Turtle Beach Elite Pro Right Speaker Replacement: 8 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Right Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Replace the old speaker with the new speaker.
    • Using the soldering iron, solder the wires to the new speaker.
    • Make sure to solder the wires to their original locations on the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexis Uribe
회원 가입일: 03/24/17
510 평판
안내서 4개를 작성함
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G1
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 1,122
