주요 콘텐츠로 건너뛰기
Turtle Beach REACT-R Vibration Motors Replacement
필요한 것
  1. Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Turtle Beach REACT-R Vibration Motors Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
  2. Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Turtle Beach REACT-R Vibration Motors Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
  3. Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: 3 단계, 이미지 3개 중 1개 Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: 3 단계, 이미지 3개 중 2개 Turtle Beach REACT-R Vibration Motors Replacement, Vibration Motors: 3 단계, 이미지 3개 중 3개
    • Be careful not to damage the vibration motors by dangling the wires.
    • Place the motherboard down on its back.
    • Grip white rumble motor connector and pull it directly out of its socket to disconnect it from the motherboard. Repeat for the other motor.
결론
작성자
2다른 기여자 명과 함께
Dodi Imam
회원 가입일: 02/16/24
637 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 12
전체 시간: 239
