주요 콘텐츠로 건너뛰기
Turtle Beach Recon 70P Speakers Replacement
필요한 것
  1. Turtle Beach Recon 70P Speakers Replacement, Speaker: 1 단계, 이미지 1/3 Turtle Beach Recon 70P Speakers Replacement, Speaker: 1 단계, 이미지 2/3 Turtle Beach Recon 70P Speakers Replacement, Speaker: 1 단계, 이미지 3/3
    • Before continuing, remove the ear pad(s) from the nonfunctional speaker(s) following the earpad replacement guide.
    • Use a spudger to pry up and remove the black plastic cover.
  2. Turtle Beach Recon 70P Speakers Replacement: 2 단계, 이미지 1/2 Turtle Beach Recon 70P Speakers Replacement: 2 단계, 이미지 2/2
    • Use flush cutters to cut the wires as close to the speaker connections as possible.
  3. Turtle Beach Recon 70P Speakers Replacement: 3 단계, 이미지 1/3 Turtle Beach Recon 70P Speakers Replacement: 3 단계, 이미지 2/3 Turtle Beach Recon 70P Speakers Replacement: 3 단계, 이미지 3/3
    • Use a spudger to pry the speaker out of its housing.
    • The speaker is attached to the housing with adhesive, so moderate force may be necessary to pry it out of place..
  4. Turtle Beach Recon 70P Speakers Replacement: 4 단계, 이미지 1/2 Turtle Beach Recon 70P Speakers Replacement: 4 단계, 이미지 2/2
    • Insert the new speaker into the plastic housing, sealing it in place with glue or tape.
    • Solder the wires in the order they were previously found.
결론
Austin Hance
회원 가입일: 02/05/24
531 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 68
