주요 콘텐츠로 건너뛰기
Turtle Beach Recon 70P Talkback Cable Replacement
필요한 것
  1. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: 1 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: 1 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: 1 단계, 이미지 3개 중 3개
    • Remove the left ear pad by following the steps from the ear pad replacement guide. earpad replacement guide.
    • Use a spudger to pry up and remove the black plastic cover.
  2. Turtle Beach Recon 70P Talkback Cable Replacement: 2 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 2 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the two 5 mm screws that secure the motherboard.
  3. Turtle Beach Recon 70P Talkback Cable Replacement: 3 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 3 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 3 단계, 이미지 3개 중 3개
    • Cut the talkback cable below where it enters the speaker housing.
    • Remove the cut section of the talkback cable.
  4. Turtle Beach Recon 70P Talkback Cable Replacement: 4 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 4 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 4 단계, 이미지 3개 중 3개
    • You may need to move the speaker wire out of site so it will not block the motherboard.
    • Lift the motherboard up and out of the housing.
    • Take care not to strain the wires.
  5. Turtle Beach Recon 70P Talkback Cable Replacement: 5 단계, 이미지 2개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Desolder all of the talkback cable motherboard connections.
  6. Turtle Beach Recon 70P Talkback Cable Replacement: 6 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 6 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 6 단계, 이미지 3개 중 3개
    • Feed the replacement talkback cable through the housing, then solder every wire onto the motherboard's connection points in the order they were initially found.
    • The purpose of each wire is designated in small text on the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Austin Hance
회원 가입일: 02/05/24
588 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 45
전체 시간: 343
