소개
This guide will demonstrate how to replace the joystick caps on your Turtle Beach Recon.
The joystick caps provide grip and control over movement and make the joystick accessible to the user.
The joystick caps may need to be replaced if they are broken, faulty, or dirty.
필요한 것
Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
Use your fingers to lift both of the joystick caps off of the motherboard.
Remove the joystick caps.
다른 한 분이 해당 안내서를 완성하였습니다.
