주요 콘텐츠로 건너뛰기
Turtle Beach Recon Controller Motherboard Replacement
필요한 것
  1. Turtle Beach Recon Controller Motherboard Replacement, Back Plate: 1 단계, 이미지 3개 중 1개 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: 1 단계, 이미지 3개 중 2개 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Turtle Beach Recon Controller Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Turtle Beach Recon Controller Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Motherboard Replacement, Face Plate: 3 단계, 이미지 2개 중 1개 Turtle Beach Recon Controller Motherboard Replacement, Face Plate: 3 단계, 이미지 2개 중 2개
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Turtle Beach Recon Controller Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Turtle Beach Recon Controller Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Turtle Beach Recon Controller Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: 6 단계, 이미지 2개 중 1개 Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: 6 단계, 이미지 2개 중 2개
    • Use your fingers to lift both of the joystick caps off of the motherboard.
    • Remove the joystick caps.
  7. Turtle Beach Recon Controller Motherboard Replacement, Motherboard: 7 단계, 이미지 1개 중 1개
    • Nothing can be further removed from the motherboard. It can now be replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mary Goodrow
회원 가입일: 03/22/24
671 평판
안내서 5개를 작성함
UMass Dartmouth, Team 6-1, Botvin Spring 2024 UMass Dartmouth, Team 6-1, Botvin Spring 2024 회원
UMASSD-BOTVIN-S24S6G1
3 회원들
안내서 5개를 작성함
1가이드 댓글
thanks for posting this!
Sean Malter - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 45
전체 시간: 628
