주요 콘텐츠로 건너뛰기
Two-Hole Button Replacement
필요한 것
  1. Two-Hole Button Replacement, Two-Hole Button: 1 단계, 이미지 1/1
    • Choose a thread that will match the rest of the buttons on the jacket/button.
  2. Two-Hole Button Replacement: 2 단계, 이미지 1/1
    • Thread the needle so that there is equal thread on both sides of the needle.
  3. Two-Hole Button Replacement: 3 단계, 이미지 1/2 Two-Hole Button Replacement: 3 단계, 이미지 2/2
    • Tie a knot at the end of the thread so that it will not come back through the buttonhole.
  4. Two-Hole Button Replacement: 4 단계, 이미지 1/1
    • Place the button on the fabric that you are sewing it back on to.
  5. Two-Hole Button Replacement: 5 단계, 이미지 1/2 Two-Hole Button Replacement: 5 단계, 이미지 2/2
    • Take the threaded needle and push it through the fabric and one of the buttonholes on the bottom side and pull it through.
  6. Two-Hole Button Replacement: 6 단계, 이미지 1/2 Two-Hole Button Replacement: 6 단계, 이미지 2/2
    • Thread the needle down through the second hole of the button.
  7. Two-Hole Button Replacement: 7 단계, 이미지 1/1
    • Place a straight pin on the backside of the button to keep the button from being sewn on too tight.
  8. Two-Hole Button Replacement: 8 단계, 이미지 1/2 Two-Hole Button Replacement: 8 단계, 이미지 2/2
    • Repeat steps 5-6 to continue sewing the button on until secure.
  9. Two-Hole Button Replacement: 9 단계, 이미지 1/2 Two-Hole Button Replacement: 9 단계, 이미지 2/2
    • Once the button is secure, push the needle through the fabric but not the button and remove the pin.
  10. Two-Hole Button Replacement: 10 단계, 이미지 1/2 Two-Hole Button Replacement: 10 단계, 이미지 2/2
    • Once the pin is removed, wrap the thread around the button 6-7 times and push the needle through the fabric on the underside of the button.
  11. Two-Hole Button Replacement: 11 단계, 이미지 1/3 Two-Hole Button Replacement: 11 단계, 이미지 2/3 Two-Hole Button Replacement: 11 단계, 이미지 3/3
    • To finish sewing, make 3-4 stitches to tie off.
  12. Two-Hole Button Replacement: 12 단계, 이미지 1/3 Two-Hole Button Replacement: 12 단계, 이미지 2/3 Two-Hole Button Replacement: 12 단계, 이미지 3/3
    • Cut the remaining thread off.
결론
Test out your fix by closing the jacket/clothing item with your resewn button!
Hannah Radtke
회원 가입일: 10/05/23
205 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 123
