주요 콘텐츠로 건너뛰기
UDI U842 Quadcopter DC Motor Replacement
필요한 것
  1. UDI U842 Quadcopter DC Motor Replacement, Bottom Light: 1 단계, 이미지 1/2 UDI U842 Quadcopter DC Motor Replacement, Bottom Light: 1 단계, 이미지 2/2
    • To open up the motor housing, first remove the bottom light by unscrewing,
    • One 6mm Phillips screw.
  2. UDI U842 Quadcopter DC Motor Replacement, Propeller Bumper: 2 단계, 이미지 1/3 UDI U842 Quadcopter DC Motor Replacement, Propeller Bumper: 2 단계, 이미지 2/3 UDI U842 Quadcopter DC Motor Replacement, Propeller Bumper: 2 단계, 이미지 3/3
    • Unscrew the single propeller bumper screw on the outside of the of the motor housing.
  3. UDI U842 Quadcopter DC Motor Replacement: 3 단계, 이미지 1/3 UDI U842 Quadcopter DC Motor Replacement: 3 단계, 이미지 2/3 UDI U842 Quadcopter DC Motor Replacement: 3 단계, 이미지 3/3
    • Push up on each of the two tabs that connect the bumper to the bottom casing.
    • Slide the bumper up off of the drone.
    • The propeller is not shown in these photos because the steps for removing the bumper and the propeller are interchangeable. Choose whichever sequence feels most comfortable!
  4. UDI U842 Quadcopter DC Motor Replacement: 4 단계, 이미지 1/2 UDI U842 Quadcopter DC Motor Replacement: 4 단계, 이미지 2/2
    • To remove the propeller, first unscrew the propeller set screw.
    • Next, slide the propeller up off the motor gear shaft.
  5. UDI U842 Quadcopter DC Motor Replacement, Motor Casing Screws: 5 단계, 이미지 1/2 UDI U842 Quadcopter DC Motor Replacement, Motor Casing Screws: 5 단계, 이미지 2/2
    • Unscrew the three screws on the perimeter of the motor casing.
    • Three 6mm Phillips screws.
  6. UDI U842 Quadcopter DC Motor Replacement, Motor Casing: 6 단계, 이미지 1/3 UDI U842 Quadcopter DC Motor Replacement, Motor Casing: 6 단계, 이미지 2/3 UDI U842 Quadcopter DC Motor Replacement, Motor Casing: 6 단계, 이미지 3/3
    • Remove the motor casing by pulling up on the edges of the prismatic housing.
    • The casing may require heavy force to remove. Be cautious to avoid breaking the mating pins (shown up close in the third picture).
  7. UDI U842 Quadcopter DC Motor Replacement, Motor Mounting Screws: 7 단계, 이미지 1/2 UDI U842 Quadcopter DC Motor Replacement, Motor Mounting Screws: 7 단계, 이미지 2/2
    • Remove the three motor mounting screws.
  8. UDI U842 Quadcopter DC Motor Replacement, Detach Motor Cable: 8 단계, 이미지 1/2 UDI U842 Quadcopter DC Motor Replacement, Detach Motor Cable: 8 단계, 이미지 2/2
    • The motor-cable plug appears to be covered in a waxy sealing material.
    • Use a thin blade or an X-ACTO knife to slice along the bottom of the wax to free the plug.
  9. UDI U842 Quadcopter DC Motor Replacement: 9 단계, 이미지 1/3 UDI U842 Quadcopter DC Motor Replacement: 9 단계, 이미지 2/3 UDI U842 Quadcopter DC Motor Replacement: 9 단계, 이미지 3/3
    • Detach the motor cable by pulling outward and gently wiggling the plug.
    • Be careful to avoid pulling off the board-mounted connector, as shown in the third photo. If the connector starts to come loose, just press it back down and it will snap into place.
  10. UDI U842 Quadcopter DC Motor Replacement: 10 단계, 이미지 1/2 UDI U842 Quadcopter DC Motor Replacement: 10 단계, 이미지 2/2
결론
다른 2명이 해당 안내서를 완성하였습니다.
Adrian Eaton
회원 가입일: 01/12/15
614 평판
안내서 4개 작성하였습니다
Cal Poly, Team 70-2, Forte Winter 2015 Cal Poly, Team 70-2, Forte Winter 2015 회원
CPSU-FORTE-W15S70G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 1,030
