주요 콘텐츠로 건너뛰기
UE BOOM 2 Battery Replacement
필요한 것
  1. UE BOOM 2 Battery Replacement, Battery: 1 단계, 이미지 1/2 UE BOOM 2 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Battery Replacement: 2 단계, 이미지 1/2 UE BOOM 2 Battery Replacement: 2 단계, 이미지 2/2
    • After the D-ring has been removed, remove the rubber port cover.
  3. UE BOOM 2 Battery Replacement: 3 단계, 이미지 1/3 UE BOOM 2 Battery Replacement: 3 단계, 이미지 2/3 UE BOOM 2 Battery Replacement: 3 단계, 이미지 3/3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. UE BOOM 2 Battery Replacement: 4 단계, 이미지 1/1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Battery Replacement: 5 단계, 이미지 1/3 UE BOOM 2 Battery Replacement: 5 단계, 이미지 2/3 UE BOOM 2 Battery Replacement: 5 단계, 이미지 3/3
    • Use a Phillips #2 screwdriver to unscrew the four 15mm screws on the bottom of the speaker. DO NOT OPEN SIDE WITH RED CAP (AS SHOWN IN SOME IMAGES), BATTERY IS ON OPPOSITE SIDE
    • Use a metal spudger to pry up the plastic cap.
  6. UE BOOM 2 Battery Replacement: 6 단계, 이미지 1/2 UE BOOM 2 Battery Replacement: 6 단계, 이미지 2/2
    • Carefully un-loop the cable with a plastic spudger and unplug from motherboard.
    • Slowly pull out the battery, and handle with care.
결론
다른 48명이 해당 안내서를 완성하였습니다.
Brandon Yowakim
회원 가입일: 01/18/18
1,200 평판
안내서 2개 작성하였습니다
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Cal Poly, Team S1-G3, Zimmerman Spring 2020 회원
CPSU-ZIMMERMAN-S20S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 26개
what kind of battery ?and do you have a link to buy one
wrig5235 - 답글
I was looking for a battery replacement all over the place. Came up with this site that carries parts for the Boom 2:
https://www.joesge.com/products/ue-ultim...
Frederic - 답글
Why is this set to difficult though? It doesn’t look THAT hard… And will this affect waterproofing of the feature?
Frederic - 답글
Because you do not simply stick the plunger in and pop those tabs. They are a force of evil and I even bent my metal tools to open mine.
Joseph Murphy -
It isn't that hard if you've done a couple of repairs, although you gotta work slow and really make sure you got yourself like 3-4 spudger like items (butter knife) and look at reference images where the tabs are. Btw. You don't need to remove more than the bottom plastics and the plate with 4 screws to change the battery. Managed to change my battery while not damaging a single plastic tab
Lucas Schießl -
댓글 쓰기
조회 통계:
24 시간 전: 62
7일 전: 358
30일 전: 1,615
전체 시간: 119,149
