이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Remove the rubber stripping using a metal spudger.
Work around the edge of the rubber stripping slowly prying up the edge.
Use a Phillips #2 screwdriver to unscrew the four 15mm screws on the bottom of the speaker. DO NOT OPEN SIDE WITH RED CAP (AS SHOWN IN SOME IMAGES), BATTERY IS ON OPPOSITE SIDE
Use a metal spudger to pry up the plastic cap.
Carefully un-loop the cable with a plastic spudger and unplug from motherboard.
Slowly pull out the battery, and handle with care.
다른 47명이 해당 안내서를 완성하였습니다.
댓글 26개
I was looking for a battery replacement all over the place. Came up with this site that carries parts for the Boom 2:
Why is this set to difficult though? It doesn’t look THAT hard… And will this affect waterproofing of the feature?
Because you do not simply stick the plunger in and pop those tabs. They are a force of evil and I even bent my metal tools to open mine.
It isn't that hard if you've done a couple of repairs, although you gotta work slow and really make sure you got yourself like 3-4 spudger like items (butter knife) and look at reference images where the tabs are. Btw. You don't need to remove more than the bottom plastics and the plate with 4 screws to change the battery. Managed to change my battery while not damaging a single plastic tab
