주요 콘텐츠로 건너뛰기
UE BOOM 2 Micro-USB Port Replacement
필요한 것
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: 1 단계, 이미지 2개 중 1개 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: 1 단계, 이미지 2개 중 2개
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: 2 단계, 이미지 2개 중 1개 UE BOOM 2 Micro-USB Port Replacement: 2 단계, 이미지 2개 중 2개
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: 3 단계, 이미지 3개 중 1개 UE BOOM 2 Micro-USB Port Replacement: 3 단계, 이미지 3개 중 2개 UE BOOM 2 Micro-USB Port Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. UE BOOM 2 Micro-USB Port Replacement: 4 단계, 이미지 1개 중 1개
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: 5 단계, 이미지 3개 중 1개 UE BOOM 2 Micro-USB Port Replacement: 5 단계, 이미지 3개 중 2개 UE BOOM 2 Micro-USB Port Replacement: 5 단계, 이미지 3개 중 3개
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Bahm
회원 가입일: 01/18/18
2,325 평판
안내서 6개를 작성함
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G5
2 회원들
안내서 15개를 작성함
6가이드 댓글
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - 답글
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - 답글
i too am looking to find the replacement part
Liam Nicholls - 답글
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - 답글
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 28
지난 30일: 117
전체 시간: 10,810
