주요 콘텐츠로 건너뛰기
UE BOOM 2 Micro-USB Port Replacement
필요한 것
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: 1 단계, 이미지 1/2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: 1 단계, 이미지 2/2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: 2 단계, 이미지 1/2 UE BOOM 2 Micro-USB Port Replacement: 2 단계, 이미지 2/2
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: 3 단계, 이미지 1/3 UE BOOM 2 Micro-USB Port Replacement: 3 단계, 이미지 2/3 UE BOOM 2 Micro-USB Port Replacement: 3 단계, 이미지 3/3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    The rubber is glued to a hard plastic part of the case that is snapped in. Must remove the hard plastic that the rubber is attached to. Not just the rubber.
    Jordan Baxter (jbax92) - 답글
  4. UE BOOM 2 Micro-USB Port Replacement: 4 단계, 이미지 1/1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: 5 단계, 이미지 1/3 UE BOOM 2 Micro-USB Port Replacement: 5 단계, 이미지 2/3 UE BOOM 2 Micro-USB Port Replacement: 5 단계, 이미지 3/3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Alex Bahm
회원 가입일: 01/18/18
2,226 평판
안내서 6개 작성하였습니다
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G5
2 회원들
안내서 15개 작성하였습니다
댓글 6개
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - 답글
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - 답글
i too am looking to find the replacement part
Liam Nicholls - 답글
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - 답글
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - 답글
I want to have the UE Boom 2
Fixed because it stopped charging while plugging my UE Boom 2
Shannon Leclair - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 42
30일 전: 163
전체 시간: 8,354
