소개
The micro-USB port is located under a rubber cover on the bottom of the UE Boom 2 speaker. Replacing this part requires the removal of the D-ring and rubber port cover, In addition the bottom pad must be removed, which will void the device warranty.
필요한 것
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Remove the rubber stripping using a metal spudger.
Work around the edge of the rubber stripping slowly prying up the edge.
The rubber is glued to a hard plastic part of the case that is snapped in. Must remove the hard plastic that the rubber is attached to. Not just the rubber.
Continue removing the rubber stripping down the side.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 6개
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
i too am looking to find the replacement part
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
Anyone have the part number to convert it to a USB type c instead of A?
I want to have the UE Boom 2
Fixed because it stopped charging while plugging my UE Boom 2
