소개
This guide will show how the motherboard of the UE Boom 2 Bluetooth speaker is removed. This is an extensive and intrusive process which removes all components of the speaker.
필요한 것
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Using the metal spudger, specifically the pointy end, find the gap between the speaker and the passive radiator (the larger rectangular speaker-like-object next to the speaker).
Pry the metal wire up and out at exactly this gap, then slide down wire towards one end to pop it out completely.
Once one end is out, use your fingers to gently pull off completely so as not to bend the wire too aggressively.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
Buenas tardes
Disculpe las molestias. En mi equipo ue boom 2 no sale audio, ya desarme siguiendo los paso y medi Ω de sus parlantes, y estan en su valor me puede ayudar con este problema.
O se puede cambiar toda la tarjeta madre.
Le agradezco de antemano .
Estare atento a cualquier respuesta.
Where can I get a new motherboard or get my current one repaired?
My Boom 2 won’t respond. Doesn’t make any sounds when pressing bottoms, and Bluetooth doesn’t work. If it’s connected to power and using an aux cord it works. But unless connected to power the speaker won’t turn on or work at all. I checked the condition of the battery and it’s voltage was perfect. Could this problem be to do with the mother board and would replacing it fix these problems. Any advice you have would be brilliant. Thanks
