소개
This guide will show how the speaker of the UE Boom 2 is removed. This is an extensive and intrusive process which removes most components of the speaker.
필요한 것
Remove the D-ring located at the bottom of the device, opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Removing the D-ring will allow you to be able to remove the rubber port cover revealing the headphone jack and charging port.
Using the metal spudger, specifically the pointy end, find the gap between the speaker and billow (the large speaker-like object next to the speaker).
Pry the metal wire up and out at exactly this gap, then slide down wire towards one end to pop it out completely.
Once one end is out, use fingers to gently pull off completely, so as not to bend the wire to aggressively.
Once speaker is detached from casing, remove cable from motherboard.
Connect new speaker by attaching the cable to the same place where the old speaker was just taken out of.
If both speakers are blown out, repeat steps 14-16 on the other side.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 10개
Hi, very good tutorial, you got your 30 points ! ;)
But the main question remains to me : where to get a new speaker as UE doen’t sell spare parts and I don’t find any replacement on internet … any help more than welcome …
Cheers!
did you managed to source a replacement speaker? im having the same problem
Still did not find replacement … what about you guys ?
Check my update you may not have to buy a replacement
Check with a multimeter if the speakers are actually faulty. Mine were fine, turns out another component broke off and so I soldered it back on. Now it works fine.
Stig -
Hi, großartige Anleitung! Ist der Bass rein Passiv? Meiner boom 2 schäpert ziemlich und ich würde gerne wissen ob ggf. Treiber auf der Platine defekt sein könnten. Ist der Bass passiv, wäre der Fall klar. Neue Treiber findet man ja bei eBay. Für den Bass allerdings immer nur die Membran. Vielen Dank vorab schon mal!
Der Bass ist nie rein Passiv. Eine Passivmembran unterstützt nur beim Bass, eigentlich genau wie ein Bassreflexrohr, nur luft- und wasserdicht, kleiner und ohne Nebengeräusche. Erzeugt wird der Bass nach wie vor von den Lautsprechern, denn diese bringen die Luft in Bewegung.
Beim Passivmembran-Lautsprecher muss die Luftdichtigkeit absolut perfekt sein. Meine Vermutung ist, dass bei Dir irgendwo undicht ist, sodass die Lautsprecher nicht mehr korrekt “gefedert” werden durch die einbeschlossene Luftmasse (und aus dem Leck Luft austritt, der ungewollte Geräusche erzeugt). Ich würde also die ganzen Fugen, mit besonderem Auge auf die Lautsprecher-Sicken und Passivmembrane sowie die Buchsen.
Zu Deiner Frage wegen der Elektronik: klar, es ist möglich, aber ich denke dass es eher unwahrscheinlich ist. Wenn überhaupt was elektronisches, würde ich am ehesten die grossen Elkos vermuten, denn Knackser kommen vor, wenn der Verstärker-IC bei Lautstärke-Spitzen zu wenig Strom bekommt. Aber eben, höchst unwahrscheinlich.
tooki -
Thanks very much for the easy points, life/music saver. Thank you! I tried a different site to take it apart, but it shows the wrong speaker, but you don’t know that until it’s too late, so mine didn’t come apart like that one showed, so I broke a few clips!
Ultimately I had success in the end, I was lucky as I took speakers out of one they warrantied for a charging issue, that I got to keep, just couldn’t use it! That’s how I got my replacement speakers, so I replaced both speakers and the billows while I was at it, nooooo more crackling sound! Yahhhh! Thank you! Worth the time and grief forsure!
If you don't get any sound out of the driver/speaker pull the wire at the back ever so slightly it will realign the voice coil within the magnet
Kyle White - 답글
