주요 콘텐츠로 건너뛰기
UP! Plus 2 Spool Holder Replacement
필요한 것
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: 1 단계, 이미지 1/1
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 2 단계, 이미지 1/3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 2 단계, 이미지 2/3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 2 단계, 이미지 3/3
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: 3 단계, 이미지 1/3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 3 단계, 이미지 2/3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 3 단계, 이미지 3/3
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: 4 단계, 이미지 1/3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 4 단계, 이미지 2/3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 4 단계, 이미지 3/3
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
valerie boyer
회원 가입일: 10/12/14
508 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014 회원
CPSU-MANESS-F14S14G31
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 22
전체 시간: 1,226
